help!m.o.t fail on emissions
7 Mar 2009
Herefordshire
hi,i have A VECTRA V6 2.5,just failed m.o.t on emmisons,checkd leads and one as no spark coming from distribributor,any ideas why????
Have had exactly the same problem with daughters 2.5 V6 Vectra,
replace the coil pack and all was back to normal.
Coil pack 100%!
It's a bit of a job to do it yourself but it can be done, new coil pack quite expensive, secondhand one? well you take a chance.
Wotan
Duff plug lead or faulty segment in dizzy cap. Try a new set of leads and a new cap.
No 'Dizzy' caps on Vectra, they use a coil pack, electronically fired by the ECU, indivdual coils within the coil pack are known to fail, either completely or intermittantely, leading to a misfire.
Wotan
Thanks for the replies :D don't know much about cars, if i follow the leads from the plugs is the coil pack where the leads terminate (what would of used to have been the distributer)?
cheers
