HELP! My boliers died
21 Jan 2007
Norfolk
I need some help; when i got up this morning and went to run a bath there was no hot water? went into my utility room and found the boiler was dead?
Besides my boiler there is a switch which was on but I thought maybe the fuse had blown so I changed that but still nothing? The boiler is switched on at the wall and on the panel at the fromt of the bolier. There's no pilot light or anything. I have no idea what has happened as I havent had any problems before.
The make is a Worcester 24CD.
I hope someone can help.
Thanx :confused:
______________________________
lynda, moderator
please note forum rule 5
Hi there, don't think I can help you, but I'm also in Norfolk, Ormesby to be precise, and know of a couple of people that this has happened to over the past couple of days. Did you lose power in the high winds recently?
I didn't but I too am now having heating problems, i.e. hot water but no heating. Posted on here to try to get some help but none forthcoming so far. Maybe it's only Norfolk related but noticed a few similar posts added yesterday and today.
Good luck with yours and I hope you get it sorted soon.
The overheat stat may have tripped and you could push reset it if you locate it from the manual.
The pump would still start up though. Can you hear the pump when you switch it on?
Tony
Is the powert light on on the front of the boiler?
:D Thanx 2 those who replied! It was absoultly nothing to do with the bolier but the fuse box. I hadn't realised but the fridge, kettle and microwave had tripped as well. Someone came round to look at it and siad we were lucky we didnt have a fire as a result of dodgy wiring :confused: scary! Thankfully we are up and running and things are gd so far!
Thanx again x x x
