Feeling a bit silly now. I was just thinking about it and when the shower was initially fitted it had to be "primed" by pressing the on/off switch. I just checked and without the isolation switch turned on the water doesn't heat up
Yes - it's potentially dangerous, because the new shower will draw more current than the old, and the installer should have determined that the increase can be handled by all of the electrical components in the circuit. The risk is of overheating, and this can start a fire.
Do not use the shower until someone competent has checked the circuit.
I thought because I was just swapping one for the other that it would be simple and straightforward.
I'm sorry to hear that, but this is something that can't be risked. If you're disabled then a fire would be even more devastating (i.e. possibly fatal) than for an able-bodied person.
I'm guessing it's just something that neither of us had seen before and is perfectly safe to use
