First check the ball cock tap and there is water in the expansion tank.
if no water manually lift the ball and gently tap the ball cock valve, still no water......if no.
Short out the hot and cold taps downstairs with a hose and clips , turn on all hot taps then the cold tap with the hose on and back fill the hot in short busrts once you get water comin out turn the tap off,
and so on UNTIL THE EXPANSION TANK.
keep close eye on it for filling or filling from the expansion loop, ITS LEADS TO OVERFLOWING so slowly do it, you should hear tho' , once you get water there turn off cold tap and remove the hose then and let the hot waterflow and clear any air.
for a quick one try the hose method for about 30 secs then remove hose and let hot tap run , keep tryin few times cos that usually works first time when you touch wood and cross your fingers, ha,....its back fillin from mains like Mike said and saves water in the mouth, and if its been emptied who knows what contaminant the water has....could make you poorly.
Good Luck
F
X
