If the mixer tap mixes water in the tap body it should be fitted with check valves which means that Agiles tip won't work. A lot of mixers that mix in the tap body already have check valves built in.
I still favour using a wet and dry vacuum in the first instance before trying to use mains pressure. There's a lot less scope for damaging fittings.
Mike
Mike
