- Joined
- 22 Sep 2022
- Messages
- 20
- Reaction score
- 3
- Country
Help got a Y type system, long story but plumber just changed motorised valve complete with motor so all new. Unfortunately he doesn’t do electrics. I have looked at the wiring diagram and checked everything through and found that the HW off wire did not connect to anything nor could I find it in the airing cupboard and hence the grey wire to motorised valve and terminal 2 on the cylinder stat were not energised. I connected both these up to HW off on the programmer using a temporary wire and was hopeful , I have checked and double checked all other wiring and all seems well. However……on HW only I am getting power on orange to fire boiler but at same time the white powers up sending a feed to the room stat which to me sounds wrong. Any ideas anyone please, I am thinking the new switching within the motorised valve maybe faulty ? It’s at a rental so can’t check tonight but if valve not set to auto would this cause this ?
on a side issue I have a terminal block with a red and yellow wire seemingly redundant that power up when heating turned on but can’t see that they are relevant to anything or connect up to anything , just curious what these may be or may have been?
Any help please ?….. Valve is V4073A Honeywell
