Burnerman/****ycranky - thanks for your comments.
****ycranky
I will try and use your termonology to explain. You are correct. The window is beaded on the outside. The fitter did remove the silicone and renew it. I thought that the window was beaded on the inside. I cannot understand how he now has chip marks (around 4 on the vertical inside frame plus some surface black marks and also one 4mm gouge on the top frame). Why would these now be hear if he removed from the outside?
He did say that there was come cement behind the frame - not sure if he has tried to force the window in or out?
I can fit a piece of card in a few areas between the window and rubber. I can fit a piece of paper all the way around the window with ease on the whole window pane. I tried this on the other windows and on the outside of the problem pane and I could not fit a piece of paper between.
I had problems before with CR Smith fitting my doors in a previous house and took this company on a personal recommendation to try and avoid probs again. They use profile 22 (I think) and only have one set of fitters, who are supposed to be good. I was going to cancel the cheque and re-issue another cheque for a reduced amount to retain until the work was completed but was talked out of it by the owner. Big mistake.
The problem is going to be if they say that the window is fine even thought it is not fully straight in the corner and the rubber is gapping. If the frame is now only slightly out, is this acceptable to a DG company?
Fluff
****ycranky
Fluff
