I really need some advice please.
My old central heating system consisted of a Baxi Bermuda backboiler, circa 1970, 2 manifolds one upstairs which I assumed to be flow and one down stairs which I assumed to be return. From the manifolds I have microbore to old radiators which have the pipes entering on the same side. Apart from the boiler making a hell of a noise it all worked well. The rad valves had broken years ago and are fixed open.
I've taken the old boiler out and replaced with a Ravenheat combi. The flow pipe comes out of the boiler, to the manifold upstairs. The return from the manifold downstairs back to the boiler. Between them both I fitted a bypass valve in readiness for me fitting new rads with thermostatic valves.
I fired up the boiler today for the first time. The flow got nice and hot but the bypass valve kept opening and returning the water back to the return side of the boiler. No water was going round the system. Its been bled and the boiler is maintaining a pressure of 1.5 bar.
I've removed the bypass valve and blocked the pipes off, meaning that water has to flow around but it makes no difference, all that happens is that the boiler trips out.
Am I correct in my assumption that the flow manifold would be upstairs and the return down, other than the water flowing the wrong way through the rads would this make a difference.
Can anyone suggest ideas why the water just wont flow through the heating system at all ?
Stu
Stu
