Help, problems setting up Pyronix XDL12TT-WE WIRELESS OUT DOOR DETECTOR
Ok, what other input could I set it to which doesn’t trigger the alarm but just notifies my phone ?
None without alarm activation.
Could use chime attribute to give audible sound at control panel when system not set.
One more addition, I have A as full set and B as night set. When the system arms for night set it is silent , as opposed to when we full set and it sounds for 20 seconds before setting.
How do I program my v11 to do the same ?
B setting default is silent with confirmation peep.
You can change sounder volume in volume settings .
Programming the same with extra functions eg WiFi setup.
Hitting Thanks button also helps?
I’m new using a forum, so is assumed typing thanks when people have replied was suffice. But if clicking the thanks button is the way forward I shall do that!
Hi, I have just installed the new v11. All fine. But having trouble with the XDL 12TT-WE. I have learnt it, set to switcher, input areas to A , input areas Any, set special log on the panel to always. Then on cloud set no 78, but don’t receive any notifications.
Any help most welcome
Just to add. I have set it on a and b. Should I have set it on c or d maybe ?
