Very interesting to see some Australian fittings, completely different to our stuff.
I remember those.Although Clipsal did make a very similar range of switches (albeit on UK plates). Up to 5 Gang on a single plate.
https://www.mr-resistor.co.uk/item.aspx?i=18302
The Crapsall range, which was usually broken before it was installed, and if not, it broke while it was being installed.Up to 5 Gang on a single plate.
BTW if you are in a similar situation again scholmore do a 4 gang 2 way switch on a "single" sized plate.Got me out of a spot where I needed a 4 gang switch in a small space.
See https://commons.wikimedia.org/wiki/File:Australian_four_gang_wall_plate.jpg and
https://commons.wikimedia.org/wiki/File:Australian_four_gang_wall_plate_-_cover_removed.jpg
for photos of the typical switches/switch-plates in question (With and Without the Cover Plate.)
With the Cover Plate the screws are not accessible.
Without the Cover Plate, the screws are still not accessible (except with a tool), because the screws are set in a small diameter hole, too deeply to be touched by an adult human finger. (6 mm deep)
Further, "back boxes" are used only in missionary walls (since there they are necessary) - and, these days, they are usually plastic. (https://hpm.com.au/product/standard-wall-box/ )
The older metal boxes were not earthed, because the construction of the switch plates and socket-outlets did not require earthing.
(However, some present day metal wall boxes do have an earthing terminal (https://hpm.com.au/product/wall-boxes-fire-120-120-and-acoustic-rated/ )
In "plaster board" walls, the switch plates are often affixed to Mounting Clips, which "crimp" over the edge of the cut-out in the plaster-board (https://hpm.com.au/product/mounting-clips-for-6-4mm-plasterboard/ ) These "clips" are not earthed.
(If the wall plate is later removed for any reason, there is a risk of the Mounting Clip falling off and down the inside of the stud wall. Hence, it is good practice to apply rubber adhesive or silicone between the mounting plate and the back of the plaster board to prevent such a "nuisance" from happening in the future.)
Non-earthed "Mounting Brackets" are affixed to "studs" during building construction (https://hpm.com.au/product/mounting-bracket-horizontal-stud-mount/ )
Socket-outlets with a (non-earthed) metal cover plate are shown in https://commons.wikimedia.org/wiki/...Metal_Cover_-_(plus_an_additional_switch).jpg
I suspected that someone might make a comment like that!Sorry but you cannot compare the fittings that you have available in Oz with the fittings in the UK. just because you say a screw is in a 6mm deep hole it cant be touched by a human fingerdoes not make it safe, what about a childs finger?? Back boxes in Oz may be "usually plastic" but not here. I thought it was only the states that had dodgy looking wiring accessories but it seems I was wrong
It is "interesting" that some have certain opinions which can conflict with those of others.The Crapsall range, which was usually broken before it was installed, and if not, it broke while it was being installed.
Can go in the same waste skip as those consumer units with 3 letter brands on them, Kidde smoke alarms and those cheapo 'trade pack' socket outlets where at least 50% broke within a month.
So what?The real point is that there is no exposed metal object on any Australian/NZ switch plate - as there is on those of the UK, North America and elsewhere.
That does not really make sense and would seem to contradict what you have been saying.It should not surprise you to learn that these screwed/bolted together steel constructions are required to be "Earthed", so that any metal electrical mounting plate which is screwed or connected to them in any way will also be Earthed.
just searched and found the switch you referred to. You learn something new everyday, thanks for that I will keep it in mind for future use. ( need a deep back box though)!BTW if you are in a similar situation again scholmore do a 4 gang 2 way switch on a "single" sized plate.
