HELP! Replacing EP2000 with Honeywell ST6400C
Actually something just struck me (lost a couple of brain cells last night!!) ...I can currently switch my CH and HW independently but the EP2000 doesn't allow me to set On/Off times independently....sorry I didn't clarify this earlier.
I am assuming then my system is ok and does just need a new programmer to set independent on/off times for CH and HW
I cant recall if you can do that with an ep 2002 i dont think so
I have a ep2002 in the stores and tomorrow night i will try and post the wiring schematic
The EP2002 cannot repace the EP2000 on gravity system because the heating & hot water systems ARE independant, in the EP2000 CH & HW times are the same, so the heating only on the EP2002 will not bring on the boiler.
May I suggest the following.
1. Buy a 2-gang surface mounted pattress (double socket box) to use as a terminal box. This is because the EP2000 terminals A, B, C, &D are just terminals for your convenience, not connected internally, the same for the N and E terminal blocks.
2. Wire the N & E wires to the new terminal block, and the A, B, C, & D likewise.
3. Terminal 5 on the EP2000 is the common and is usually linked directly to L, the new Honeywell controller has this internally linked, so all wires from 5 go straight to the L terminal.
4. Connect N & L to the new programmer base, screwed to the pattress, the old terminals 1, 3, and 4 are the same so should be a straight swap.
Finally make sure you have a 3A fuse in the supply before you switch it on, just in case...... :oops:
It can mate, you have a slider on the back that changes it from fully pumped to gravity hot water and pumped central heating, exactly like the ep 2000
not that it matters a jot
Having drawn and stared at the current wiring for days ( :eek: ) I think that actually makes sense to me :)
It doesn't have the 3 amp fuse anywhere so that will be my first port of call!
Thank you guys for taking the time to give advice I really appreciate it.
