- Joined
- 30 Sep 2006
- Messages
- 17
- Reaction score
- 0
- Country
Hi all,
I'm having a little trouble getting some celing lights to work. The house is new and I've done 10+ so far without any issue. The living room ones are proving tricky!
There are two lights in the living room. I took the old rose off the first and it has 2*Earth (G/Y), 2*Neutral (Blue), 2*Live/Loop (Brown). The second has 1 of each.
I used a new connector block to connect GY-GY, Blue-Blue and Brown-Brown and the same for the second set of lights. There are three arms on the lights (Brass next Franscesca in case anyone has experience of the same lights)
After connecting both set of lights, 1 bulb on the first set of lights comes on and two on the second. I have checked the bulbs and reconnected all wiring to ensure it is tight.
Can't think of anything else and now a little stumped. Any thoughts greatly appreciated.
Thanks...David
Thanks...David
