HELP! Tank keeps filling up!
Update
Fitted the single check valve on the mixer tap downstairs (hot pipe) and problem still persists.
Think it's time to get someone in....... :confused:
have you not got any isolation valves on the mixers ?
makes life easier to find which one.
I'll try that. If I can find out which mixer is the problem, will it still be a case of fitting a check valve?
Last throw of the dice. Will post update tomorrow.
ps water from overflow is warm water
Isolated both the shower mixer and the bath tap one at a time, shower first. Definitely an improvement. Still a slow drip from overflow.
Then isolated the bath tap. No change to overflow. Still slowly dripping.
