- Joined
- 21 Nov 2011
- Messages
- 7
- Reaction score
- 0
- Country
Hi,I have just moved into rental property and I have a timer for the immersion heater downstairs that was not working and was using the isolator switch upstairs to put the heater on /off for the water .(but kept forgetting to switch it off)
So I took the old timer off to get a replacement , and the heater still worked with the isolation switch only , does this mean that the timer has not been connected from the isolator to the element ?
A bit confused as I don't want to replace it if it's not connected to it .
The landlord doesn't know either.(not interested in repaiing)
Would the isolation switch still heat water when on , if no wires are connected to this other box for the timer.
I wouldn't think so but I'm not an electrician.
any help would be gratefully received.
Thanks. Tina
Thanks. Tina
