HELP !!!!!!!! (unvented hot water cylinder)
Status
Not open for further replies.
4 Nov 2009
Derbyshire
i've just fitted an unvented hot water cylinder to save costs i didnt think i need pressure relief valves and thermostat relief valves. some1 told me i need then. is its acceptable as it is????
err whats the word
NO and don't use it :eek:
this has to be a wind up
We get some pratts on here :eek:
Perhaps the OP is hoping to send Nan on her way a bit quicker, to get his hands on the inheritance. :idea:
You surely must remember from your unvented hot water training!! :eek:
Oh, you didnt do it,then you shouldnt of installed an unvented,as you are clearly not competent to do so :evil:
Building control will pick up on it when the OP notifies the work. :rolleyes:
the best example of what can happen when an unvented cylinder is fitted without a PRV, was on discovery channles myth busters.
the darn thing exploded and shot up like a rocket to over 100 feet high, after completely destroying the mock up room they fitted it in. the dummy lying in the bath didnt fair well after this...
DO NOT USE IT!!! LET COMMON SENSE PREVAIL BEFORE YOUR NAN IS KILLED OR INJURED
Status
