Help!!! Upvc door with low threshold leaking in water
So how would i install the drain you posted in your link. Dig down from the outside under the threshold and put it into place under the threshold? I think if the door weather strip was bigger the water might run off on the concrete away from the door threshold would it work.
I may try lowering the door first to see if it will make a better seal.
