Help with automatic bypass valve
Slip. I don't want to fall out with anyone on here over such a small issue. I apologise if I've offended you. Now back to the business in hand.
OP, without flow rate data maybe your only option is to adjust the bypass so as to give a 20c temp difference across the boiler. I can't think of another way of setting it up. Maybe others on here can shed some light on the problem?
