Hello I have a Glowworm boiler and a fully pumped system on a Y plan with a Tower mid position valve
The fault is as follows
When the programmer is switched to heating the boiler fires and the heating reaches temp etc..
When the programmer is switched to hot water the boiler does nothing
If when the heating is on I also put the hot water on the boiler goes out and stys out until hot water is switched to off
So far I have checked that there is 240v going into the programmer and 240v coming out of the programmer on HOT WATER ON if the cylinder stat is turned up
If I turn the cylinder stat down there is still 240v at HOT WATER ON and nothing on the grey wire ( hot water off I think ? )
I thought that it looked liked faulty cylinder stat so replaced that but the fault is as before
Whats the next step ? Programmer or actuator ? anything else ?
Many thanks for any help
