Well I've quoted one already - though I have no idea what the actual current was.
The chokes of standard fluorescent fittings often get 'too hot to touch' in normal operation, so I suspect that (unless it burst into flames) the example you quoted did not necessarily involve a lot more current than 'normal' (you did admit that the fuse didn't blow).
Don't forget that it's not necessarily one fitting that has to take (eg) 9A - there may well be other loads on the circuit as well which you can subtract from the required current.
Yes but, again, don't forget that I was talking about rating of the
switch (unlikely to be controlling more than a small number of fairly small loads, particularly in a domestic setting), in a lighting circuit. I still think it would take an increadibly unusual and extremely rare situation for such a switch finding itself carrying enough 'fault' current to trip a 6A MCB but not the 'very high fault current' that would trip almost any MCB.
BAS has also come up with a potential "fault" load source. I've seen houses where there are sockets for floor standing lights which are switched at a wall switch. I'm sure you can imagine a few people who might not understand the limitations of what is OK to wire into an unfused 2A plug
But now you're talking about overload, not fault. As we've discussed before, there is a limit to how far a designer can (or, I would say, should) go in trying to antipicipate all the crazy things people might do in the future. I would say that installing a 2A socket was a 'reasonable' (albeit not guaranteed) way of minimising the changes of someone connecting a high load controlled by a 'lighting' switch. In any event, even the 10A switch would be 'overloaded' by a 13A load that some idiot decided to connect tyo a 2A plug! In BAS's example, I doubt very much that many people put switches (of any sort, unless FCUs) in spurs to 13A sockets off lighting circuits.
When I look back, with what I know about electricity now, I sometimes wonder how I'm still alive. Two core extension with a croc slip to put on the nearest water pipe anyone ?
I think that a good few of us can identify with that! In my teens, I experienced a good few shocks (some bordering on above-LV, per today's definition), any of which (I realise in retrospect) could have killed me - but didn't! I then rapidly developed much more respect for electricity, and can recall remarkably few shocks, and certainly no 'serious' ones, in the last 40 years (looking for some wood to touch!).
Kind Regards, John.
