Good morning all,
As the subject suggests, we are looking at buying the above water cylinder, to replace our current hot water tank. Having read up on the above cylinder it comes with two 3kW elements, instead of the one element that the old one has. My question is- Why the two elements? At the moment there is 20A supply where the tank has to go, but if both elements need wiring this will obviously need looking at. My thoughts are that the two elements are possibly for an economy 7/10 tariff? However there is no such tariff where the tank is going, only standard tariff. If both elements need wiring, how is this set up? E.g. Off of a 32A MCB into two FCU's? Or two seperate MCB's, one for each element? Hope this all makes sense!
