"You will need two B16 circuits off the consumer unit, wired in minimum of 2.5.sq.mm cable, to a pair of 13amp DP switched fuse-connection units in the cylinder cupboard, and then 1.5.sq.mm immersion flex from each FCU to each element. "
Sorry but water heaing elements over a certain litreage (can't remember figure of the top of my head but 15 ltrs sounds familiar) must be supplied by a 20 apm double pole switch and not a SFCU.
