Hi
Could somebody please help me with a wiring problem? I am replacing an old dial timeswitch with a Drayton LP711. I made a note of how the old timer was wired which was L and N from switched fused supply, L and N from boiler into the same L and N as supply with also white cable into terminal 2. Lastly room thermostat was L into terminal 1 and N into terminal 2 with the white cable. The old timer stated that 1 and 2 were the load, 3 and 4 were unused. I replicated this wiring on the Drayton LP711 so have L and N from supply and boiler, L from stat in 1(com) and N from stat and white cable from boiler in 2. I noted from the instructions that terminal 1 has no supply so looped in a cable from the L.
The outcome is the boiler turns on and off when turning the stat up or down, but it stays on when the timer turns off!! Do I need to move the cables from 2 to 3? Or do I need to split these, with one in 2 and one in 3? If so, what way round?
Please help.
Please help.
