Hi I have a henrad 40FF (this is an ideal boiler not sure exactly which model). If anyone can tell me the ideal boiler model this would also be useful.
I am having a problem with it starting up, when I turn on the pump for either the hot water or central heating then it starts the pumps etc. but does not fire up (Pico auto lighting unit) the problem seems to be a lack of gas being supplied as though it isn't detecting something.
It starts after removing a red pipe attached to inside of case, and sucking and blowing a couple of times on the red rubber tube, I never do this with the boiler or pump running, in case this could cause a problem.
It usually takes 2 or 3 attempts to get it fired up but once it is fired up then it stays on fine until it has provided enough either hot water or the central heating has reached the desired temperature.
The turning on and off of the knob has subsequently worn this out and I now need to get a spare (shouldn't be a problem as I know a guy in the factory at Ideal).
Any thoughts on the non ignition would be greatly appreciated.
About 5 seconds after the pump starts there is a like buzz for a few seconds from the boiler which I believe is the igniter trying.
