Scenario is 4 double and 2 single flourescent light box fittings in a suspended ceiling. The lamps are PLL 4 PIN COL840 55W. (240V)
They are all fed from one gang of a standard 4 gand light switch. They intermittently stay off, come on or flicker together.
Would you suggest it is the internal switch contacts poor connection, or could it be one or more of the tubes or control units causing this ?
The only common point is the switch (and the wiring feed, dont know if there is a JB in the circuit)
Thoughts ?
Thoughts ?
