So both floors will be solid?
Sounds like your need to supply some metal box trunking in the scree down the central spine of each floor and peel off to positions via metal conduit.
Make the trunking 2 compartment and that's going to cover the data, comms, access, security and AV on one side and the 230v in the other
Ground floor level will cover ground floor only
1st floor will cover lights for ground and 1st floor floor positions
1st ceiling and loft area via roof void which could be trunking, tray or open (run in the eves) and clipped / tied.
At 6500 sq ft each floor must be 3000 sq ft plus, so I'd look towards a commercial office style design with some floor sockets for islands such as mid room furniture and access traps to get to the containment at anytime in the future for add ons and servicing.
I'd have thought you would have already talked this over with the client, builder and architect since the build design will have to make allowances for high density cable volume and as such routes, risers, containment, positioning (alarm panels, smoke detection system, racks for Cat 5 + hardware for AV, net, data, then there's mood lighting control, external lighting, external security, access control, video entry and numerous other elements).
Site would be 415 3 phase which will add to the installation works- I'd assume central panel with phases being fed to 3 areas for distribution, balancing the load.
I'd go back and arrange a 'brief' and sit in tandem with the heating and vent guys.
M & E will have air con, waste, heat, HW and CW considerations which from you very, very basic information will also have issue with the solid concrete design you have described.
Once the whole picture for all services is confirmed the architect will then have to provide a build design that accommodates all the site M & E requirements- dry and wet risers, routes, locations for services from the suppliers, locations for amps, hubs, sky boxes, distribution centres, consumer units etc, etc.
If you want further thoughts then please clarify the build design in a more comprehensive post.
On a side note if you want help (and 99% of the peeps here enjoy helping) then I'd suggest you attempt to be a little less 'edgy'.
