Hi All, Newbie Here in midst of extension
time for another update, house is all but complete with just one side of the garden fence needed putting back up once i have the feather edge board.
The main thing i wanted to get done was the garage :)
I guess its one of the things, its either just a garage for storing junk that you think you might use one day and never do or for other household stuff like washing machines etc... My garage has and will always be for my car (and motorbike) it was before but was just brick wall and an open roof space.
I had a specific theme in mind but as i have taken my time, colours changed, storage changed as did flooring, finishing etc.
Anyway, thanks to photo bucket, I deleted my account so all the previous links were lost.
Heres how the garage was...
37_zpsph4fnpvq by Gary ORourke, on Flickr
work in progress, The roof was taken off the walls extended forward
64_zps67fxhmyq by Gary ORourke, on Flickr
The steels went in and the poi joists fitted
73_zpsqml5cmeu by Gary ORourke, on Flickr
You can see the new concrete at the front showing how far it was extended forward...
EC17F529-60C2-4777-A0F3-E160593A9245_zps9w6pgrst by Gary ORourke, on Flickr
OK i won't bore you too much with what and how I did it as its pretty much common sense
The skirting and dado rail (of sorts) were treated and glossed
The tiled floor is a hardened worksop tile 300x300 with anti slip qualities
The anthracite gloss units were purchased fro Howdens (kitchen units)
Garage Finished by Gary ORourke, on Flickr
Due to the way i had to install the roller door it left a 300mm reveal and didn't want to plasterboard it due to ingress of rain water when the door opens so i purchased 2 x 4m lengths of 400mm anthracite fascia board, cut them to size at screwed them to the brickwork, using the matching corners to finish it off
Finally where the boiler was situated i built a frame and insulated all around the pipework etc, then ordered some 5mm anthracite perspex cut to size. I then had to trim, cut out the plug and screw it to the frame to finish off the look of the garage.
The company who provided the perspex (via eBay) were excellent and their cutting to size request was spot on :)
Well only one or two updates left to do to close this off.
thank you so far for viewing
I think you could have made a bit more effort with the garage ;). Possibly the best I’ve seen..... what car have you got?! :LOL:
So apart from some touching up here and there, hanging a few pictures and a small part of the loft to add a layer of insulation too (but not in these temperatures o_O ) all the big jobs are complete with this last update being the conclusion of my DIY project...
As it was a starter home that SWMBO never wanted to move from and the fact we are surrounded on all sides, our garden is both an odd shape and small. With an (now 7) only child play space was not an issue and we spend little time in the garden, mores out at the park or elsewhere so a low maintenance garden was what i needed. A place we could chill out and not worry to much about the upkeep.
so the original look was this
1 How it used to Look by Gary ORourke, on Flickr
f6c19763ce1d9e8c40f18af10c85300a_zpsef2c3376 by Gary ORourke, on Flickr
1_zpsmiaewhey by Gary ORourke, on Flickr
