High condesation - UPVC soffits and facias ?
2 Jan 2012
Hampshire
I would like some advice on if I need and therefore who to use, for replacing my soffits and fascias.
I get black mould spots on 2 upstairs bedroom walls and ceilings (north facing) and the bathroom ceiling (south facing).
The current soffits and fascias apparently have an element of asbestos in them.
I have a dehumidifier running upstairs during the day and this keeps the humidity at appx 50-60%, but this increases to 80% when not running.
One of the bedroom windows is always wet with condensation and is fitted with a trickle vent.
The downstairs toilet (directly below the bedroom with the wet windows) also suffers with high condensation (wet toilet cistern and also wet walls) and the window is always slightly ajar.
The property is in Andover, Hampshire, mid terraced and was built in the 1970's.
I had the cavities and loft insulated appx 2 years ago.
The downstairs floors are concrete and the upstairs wooden boards.
The central heating thermostat is set at 20C during the day and 15C during the night.
There are no vents in the upstairs bathroom or downstairs toilet.
What has replacing soffits and facias got to do with condensation inside the house?
If you want to solve the condensation problem, then lifestyle changes are required: //www.diynot.com/wiki/building:condensation_in_houses
If you want new facias/soffits, then get a few quotes from companies in your area, making sure to specify exactly what you want done.
Funniest post I've seen all year. :rolleyes: ;)
I was told that the loft should be ventilated via the soffits/facias (Anglian Windows) and that this could be the cause of the mould spots on the ceiling.
Correct
As a secondary reason , possibly, but the primary fault is not venting your shower-room with a sufficiently-sized vent-fan.
Really you should also prevent moist-air from getting into the loft either by using foil-backed platerboard or a vapour-barrier, but that's re-building work.
Do you dry a lot of cloths on radiators ? if so this could be the reason as this can create a lot of moisture in the house and it can turn to condensation on windows and also exterior (cold) walls I see it quite often !
Yes the loft should be ventilated too but only to let the timbers breath and not dry out, A ventilated loft does not make a house more ventilated as minimal air should get in loft from house hence the reason we use insulation in lofts.
No. Insulation prevents heat-transfer, passage of air needs to be prevented by an impervious physical barrier
I stand corrected although insulation can reduce any air loss in to loft. Any way My main point is house ventilation and loft ventilation are two seperate issues so to the OP "the soffit and fascias are not causing the mould"
In simple term, the more insulated then more ventilation, wasn't like this in the old days, draughty windows, open fireplaces etc. If you put a big plastic bag over your house then you will have condensation problems
Ventilation, ventilation, ventilation!
