I need to replace the 'water to water heat exchanger' on a Worcester Highflow 400.
To do this, I am going to remove the 'Pressure relief discharge pipe' and cut the discharge pipe (which leads outside) just below the funnel. This is because the funnel is riveted to the 'support bracket' which shrouds the 'water to water heat exchanger'.
Then, I will remove the five screws (9, 10, 13, 14 & 15) that hold the 'support bracket' to the top and bottom manifolds. This will release the 'support bracket' and the 'water to water heat exchanger' at the same time.
I will then replace the 4 "O" ring seals (at the back of the top and bottom manifolds) and reassemble with the replacement heat exchanger.
I will solder the cut pipe with a capillary joint.
Simple at that!
Or is it ?
Simple at that!
Or is it ?
