Why is the 'third' hinge often not in the centre of the door? Offset the tendency to pull out at the top?
Ta.
It's specified for doors with closures......usually seen on office doors with a vision panel, which are quite often FD60 1 hour fire doors.
The most likely point of failure on a heavy door is pull out of screws in top hinge - because that's where the greatest load is.
Door hinge screws are under very little shear load as the hinges rest on the cut outs.
The bottom hinge screws are mostly in tension.
For timber doors I've always done 150mm down, 200mm up and one half between hinges.
