My point was, in relation to this:
Assuming you live in England:
Minor work, unless carried out in a special location do not require a notification application to building controls.
The areas that generally require notification are new/change of consumer unit, new circuits and new electrical installation within the bathroom zones.
Some minor works do require notification.
Which is not quite correct.
I was pointing out that the type of certificate is irrelevant to notification (or not) and
notification (or not) is irrelevant to the type of certificate.
The type of certificate depends on the work and the details you wish to record and has nothing to do with whether it was notifiable (or not).
To avoid being picked up
, I also qualified it with: "with so few notifiable jobs now, more often than not notifiable work WILL come with an EIC"
Replacing CU will require EIC
New circuit will require EIC
Additions or alterations to circuits in zones could be either.
Two and a bit out of three is more often than not.
So, what I wrote above is correct, "more often than not notifiable work WILL come with an EIC",
BUT this is not
because the work was notifiable.
