OK, so I've just had a new boiler installed and changed my single channel to dual channel receiver.
Thermostats in the kitchen (don't ask me why the engineer installed there...) What I've discovered is as soon as the temp. hits the target in the room its in, it considers all the rooms in the house at the same temp which is the furthest from the truth. Upstairs is always much colder - which results in me having to take the thermostat upstairs to get the heating upstairs working.
Is this how hive works?!?!
If so, then I'm thinking I need a multizone setup - I've tried to call British Gas/Hive to try and get this setup and theyve quoted me £100 which cant be right as I need pipes redone from upstairs to the boiler. That being said they said I can use my old thermostat paired up with the same receiver as an alternative solution. But how does that make sense? If I want a floor hotter than another floor how is the boiler going to manage that without any pipework done?
Can I setup 2 thermostats to 1 receiver?
How much will it cost to setup a multizone setup if it involves piping re-doing?
