Stem would you not agree there are instances where valve spindle will inhibit actuator restoration to home position besides microswitch failure?
Danfoss valve is a prime example of this happening- stock both actuators and valve bodies. An estate not far from me uses these valve on three zone systems where either can be the case
Removing the actuator from the valve in this instance releases the actuator and the aux switch. If switch still made, then what you and Ian say is the way forward, else valve will need replaced
