Hello,
I previously got advice from your goodselves re: wiring a hob and oven. I ended up wiring it as below: Now the hob seems to be dying so have checked wiring and all seems o.k. but going over posts I see that some posters have recommended that 'If the installation is carried out properly, both the oven an hob should have appropriately rated fuses / MCBs for their respective loads and a local isolating switch should be provided.
So my question is would a FCU like this
-http://www.diy.com/nav/fix/electrical/switches-sockets/white-switches-sockets/connection_units/-specificproducttype-fused_spurs/MK-DP-Switched-Connection-Unit-Spur-With-Neon-White-13A-9289779?skuId=9299478
fitted between the oven and the dual connection unit - in the middle of 6mm wire going between the two - sort this issue out.
I'd like to connect my new hob in the best / safest way possible. Thanks
(Distance between CU and Cooler switch is 6m and between switch and appliances 1.5m)
