Yes, what Bernard recommended there are buffer chips to go between the logic and the relays. That's one of the ways of dealing with back EMF, but as John said, that's be a problem whatever the voltage of the relay coils.
Are you talking about the reference in that thread to 'back EMF'? If so, that's an issue which has to be addressed with any relay driven by semiconductor circuity, no matter what coil voltage (5V, 12V or whatever).
Kind Regards, John
Yes, I think that's all it's saying. They're talking about using buffer chipsto provide the protection but, as has been said, you could just as well use a transistor (with a 'reverse' diode across the relay coil to protect the transistor from back EMF).Specifically the bits below but having re-read I think he is just saying just make sure that the circuitry is protected from back EMF of the relays regardless of what they are.
Kind Regards, John
Yes, but the 'optocouplers' will provide isolation, but will not protect the driver circuitry (transistors or whatever) from back EMFs. However, if you're using a ready-made 'relay board, it will probably have the required protection built in.The PCB has optocouplers for isolation so this should be OK. I went around the houses a bit but I think I can actually use the standard 5v relays rated at 230v/10A.
Great - that's all you need, then.Yes, the board has a transistor and a diode across the relay.
So with relays fitted in a consumer unit all may be A1, but the same relays fitted in an adaptable box on DIN rail may not be accepted.
Provided the cabling is well thought out the mains cables can be left in place with only the "intelligent" unit being removed and cables from the switches on walls then connected directly to the corresponding relay. Then the only "abnormal" item would be the 12 volt DC power supply for the switches and relay coils.,and its value would drop as it would all need ripping out before it was sold.
Using assembly language is "inconvenient" but using a high level lanuage requires the hardware to match the language and this imposes restrictions on what can be done and can waste a lot of resource in the processor.however I found programming PIC's hard,
There is a balance between price and ease of construction. Using a PIC and optical isolators you can make it very cheap, however I found programming PIC's hard, however use a PLC and programming is far easier but the cost is higher. So step one is to decide what level is your programming skills?
So the way around the problem is not to make the Automation fixed, but have it so it can be easy removed.
