Just had a home buyers survey carried out on a flat that we are in the process of buying.
Had the following under the Electricity section:
"Safety warning: You should have your electrical installations inspected and tested regularly to protect your home from damage and to avoid putting your safety at risk. Guidance published by the Institution of Electrical Engineers recommends that electrical installations should be inspected and tested at least every 10 years and when the occupiers of the property change. All electrical work carried out after 1 January 2005 should be recorded on an Electrical Installation Certificate. Mains supply is provided with the meter and consumer board located in the ground floor hallway. The installation appears dated and some arrangements (electric fire in the bathroom) may not comply with current regulations. You are advised to instruct a qualified electrician to safety test the installation providing all costs for any necessary upgrading and rewiring. Condition rating 3"
I have no experience of working with electrics...what should I be asking my local sparky to look for? What would be a reasonable quote to get this sorted?
Thanks in advance
Thanks in advance
