honeywell 3-way motorised valve
9 Mar 2009
Essex
I have just replaced the motorised valve because it was stuck in the mid-way position and I have the following problems.
1. The valve ticks when hot water switched on a the controller
2. The hot water is just like warm even thought the pipe from the valve to the hot water cylinder gets hot.
What is wrong?
Thanks in anticipation.
I Changed the whole thing.
I found the cause of the ticking. The hot water thermostat was not held tightly against the hot water cylinder. The strap had worked its way loose. I tightened the strap and now things are working perfectly.
Thanks for the reply though.
