Motorised Valve
The blue wire is the Neutral for the valve motor and should go to the neutral terminal. You can usually identify this quite easily as all the wires to the terminal will be blue.[/quote]
Again spot on, all the blue neutral wires were going into connection 2 except the one from the valve, I thought it looked strange and as per your diagram I changed it.
Thanks for all your help with this it has been appreciated.
D_Hailsham";p="909440 said:
It appears you are not alone! I have just come across a post on another DIY site with exactly the same problem!
I joined that site, gave some good, accurate, useful and relevant information not contravening any of their rules and got deleted.....think I will stick here!
