Hi all,
I have installed above alarm.
Powered up. It came up with tamper lockout. Found one pir not working, loose wire fixed that.
Alarm panel now clear. When I put in walk test they are all 0 's except zone 8 (set as unused) and T which had F under it. I'm assuming that this means there is a tamper fault somewhere.
When I put in unset mode as soon as I walk past first pir alarm sounds (well internal speaker)
Any suggestions.
Could this be because of possible tamper fault.
I have checked this pir and all was properly connected.
Darren
Any suggestions.
Darren
