you need to check that optimisation is disabled. On the cm67 they come with it enabled. setting 15op needs to be set to 0.
if not the unit will try achieve the desired temp by the time you have chosen ( can come onor switch off up 2 hours prior to time)
so you would end up with worst case senario the following
boiler comes on at 04.20 till 06.20
switches off at 06.20 till 15.30
switches on 15.30 until 18.00
