- Joined
- 20 Oct 2015
- Messages
- 2
- Reaction score
- 0
- Country
forgive the basic errors I'm not an expert on any of this. We have a hot water tank and gas central heating it is controlled by a dial thermostat and a Honeywell st699. The one day two cycle one...
If the system calls for hot water OR central heating then there is no issue and it works fine, however if it calls for both via timer and hen thermostat for heat the system appears to trip. The st699 goes blank and the digital display disappears as do the orange lights. To reset the system all I have to do is turn the power on and off again and then the system works fine again until the call for both occurs again and the process starts again! The time is fine after the local trip so the battery must be ok but I can't figure what is gong on as I don't have to reset a circuit breaker or change a fuse, it's literally a turn it off and on again fix that I'm having to do twice a day!
All ideas welcome
All ideas welcome
