Honywell GD 48 with smoke detectors
I think to define the output as fire or fire delayed? It is ok?
Output will be pretty much always active if defined as fire. Is you plan to then change the output status in order to power the alarm off/on? Will the panel go into fire/tamper mode if power is lost?
Hallo again
So I allready set the output as fire, this output change state only if a fire zone changes state (in my case goes into alarm).
It will provide 12 Vdc to the detector and only when in fire alarm it will cut off the 12 Vdc, the detector/s will be reseted, the operator will enter a valid code and everything will go back to normal.
And no, there will not be any other alarms.
