Hopefully a quick cooker instal question
does 26A vs (probably) 20A not represent a bit of an electrical difference?
Technically, I suppose that is true but as neither appliance can create an overload I would not be concerned.
I am surprised the igniter is said to require a 13A fuse - 3A would be adequate - a 13A flex being supplied and the reason, I presume.
Although, considering the demand for a NICEIC installer, perhaps the other instructions are not best thought out
Were it not a DIY forum, I would propose a different connection method.
True, but with the '20A' (if that's what it is) option, the designer has no control over what the loads are - which could theoretically be as high as 26A!
I am surprised the igniter is said to require a 13A fuse - 3A would be adequate - a 13A flex being supplied and the reason, I presume. Although, considering the demand for a NICEIC installer, perhaps the other instructions are not best thought out.
Indeed, although BS7671 theoretically does not give one the option, I would feel inclined to take all of these MIs with a pinch of (common sense) salt!
So would I - but not 'in public' in any sort of forum! For the OP's situation, either of the options that have been mentioned would obviously be fine.
Kind Regards, John
Thanks so much for all the replies. It's really appreciated.
I had been leaning toward the double socket, but now thinking about it space may well be an issue. And I don't really want to be cutting in to units as they've only just gone in and been put in very tidily. Will have a look at available space and decide where to go when I get home.
Although I am now very intrigued by these "Other" methods :evil:
Absolutely fair enough. One thing I do know about electricity is that it's not something to get wrong :D
