Hi there,
I have a new hot water cylinder fitted by a builder, after works completed everything worked perfectly for three months, then I completely loss the hot water, nothing is coming out off the taps.The fuse and power are find, the water is heated normally but impossible to get any hot water from the taps,the hot water stays into the cylinder, it doesn't even go in the pipes.externally all the pipes seems good.
I would like to drain the cylinder in order to check the hot water pipe entry. The manufacturer's instructions book says to do so by closing the cold supply entry, open hot water tap, but I cannot do this because nothing is coming from the taps.I tried the safety assembly valve to empty the cylinder but it doesn't drip continuously, I don't think that I will manage to drain the thank by this way. The cylinder is : Chaffoteaux & Maury 1OO HORB 560 THER MO. 6bars 100Litres. with a pressure limitation device on the cold water inlet. 230V, 2000W.
I would appreciate if anybody could help on this matter.
Regards,
Mike67
Regards,
Mike67
