Pumps have two pipes, an inlet and an outlet!
Would you like to take a photo and post it here?
Tony
You can get a grundfos pump plan as this
http://www.plumbnation.co.uk/site/grundfos-upp15-50-pumpplan-twin-headed-domestic-circulator-pump/
Have a read of this
http://www.horstmann.co.uk/downloads/ElectronicDocuments/Packs/SMCReplacement2.PDF[/QUOTE]
thanks tamz, very interesting info. That pump sure isn't cheap! Ignorant's question: would it be possible to just substitute the 3-way HW pump with a standard 2-pipe one placed on the pipe to the tank, plus a bypass to bring water directly to the CH pump? Essentially the pipe from the boiler splits in two and feeds 2 separate circuits, each with a standard (2-pipe) pump, one controlled by the room thermostat, the other by the cylinder thermostat.
You probably need a new pump as well as a three port valve and some rewiring. Not a very big problem. I am surprised that your plumber could not see what was needed. Or perhaps he thought that you did not want to pay for whats needed?
Smc pumps were very reliable.
It didn't take much to stop them turning. so it is possibly just sticking. Tap it with a hammer and see if it starts or strip it out and check the impeller turns freely.
I would advise you to get it converted to a Y Plan layout - unless you are intending a boiler change anytime soon - in which case go for a good System boiler with built in pump and diverter valve, or a heat only boiler with a new pump and Y Plan - and weather compensation for the thinking man.
Continue with the immersion for a brief while if you plan to have a new boiler soon.
For anyone interested, it's all fixed now. I converted it to S-plan, not Y because I only have a 2-core wire going up to the hot water tank.
