I think I know what my problem is, but would like an expert opinion please.
Over the last couple of months, when I've got the heating on and it comes to that special time for the hot water to be heated so I can have a bath, there has been a loud banging / humming through what I believe to be the central heating pipes like water hammer. It lasts for about 5 - 10 seconds. It frightens the sh ! te out of me when I'm not expecting it, it's that loud !!
Over the last few days, when I've come to have a bath, the water hasn't been that hot. Also, when I switch the heating on, sometimes it doesn't come on, unless I switch the hot water on as well ??
Sooooooo.... I'm suspecting the diverter valve. I think the water hammer has been because the diverter valve has been moving across so slowly because it's on it's way out ??
Could you please explain to me if the diverter valve lever arm should move across when there is a call for hot water ?? Or does it happen internally and the arm is for manual operation only ?? At the moment the arm is not moving when the heating is on and there is a call for hot water or to heat the hot water.
Any advice would be warmly welcomed.
p.s. - It's a worcester heatslave 15-19 with a honeywell diverter valve (V4044F1125)
