hot water but no heating
21 Jan 2004
gas central heating.we only seem to get central heating if we run the hot water taps..the boiler is an ideal w2000. with grasslin towerchron programmer 2 motorised valves honeywell t40 room stat ..havent been in the house long and am wondering if its been wired up wrong ..help !! pump runs ok..
You may find that your Heating motorised valve had stopped working so someone has latched it in the "manual" position. Look at the lever on the end and compare it with the HW one. May well only need a new motor. <£15 in Wickes, or cheaper by mail at bes.ltd.uk .
nope checked valves and they seem ok..is it possible that the room stat may be at fault .i say this because it looks like a fairly new addition and on inspection of the connection box the wiring looks scruffy and i wonder if it wasn't a pro job but a bodge.is there any way of getting a wiring diagram for the system or a way of checking it .the stat clicks as it should on moving it back and forth . ;)
I don't see how you can say that the valves are working OK if you haven't been able to operate the CH one with the room stat? Y plan diagram is on the Honeywell site. Room stats have different pin names and numbers so you have to ne able to check it with a meter, though if it operates the vlave correctly it must be ok. The valve turns the boiler on not the stat.
if i take the motor head of and turn the valve to open .on turning stat up till it clicks .should the heating start ?
