C
chrissib
OK the fix lasted some time but finally gave out. I bought another cylinder which I have now installed ok.
I have lovely hot water, however, the new tank seems to be too efficient. Water heats up in no time and is much hotter than before. The old tank was much, much heavier and I had 'wrap around' lagging. The new tank is much lighter, and has an 'inbuilt' foam jacket.
Two questions... a) could the water be getting hotter because the thermostat is strapped to the outside of the foam, not to the bare copper tank. Worried about the water getting too hot, boiling or bursting...??
b) slightly different question, I am not using the heating side of the system now, but with only the boiler heating the water, is it normal for the central heating pump to be running the whole time??
Regards Chrissib
Regards Chrissib
