Tell me, does a cylinder stat turn off when the top 1/3rd is60c or when the stat at 1/3rd up reaches 60c, meaning the water at the tap could be nearer 70c.
If the boiler flow temperature is correctly set at about 65°-70° then the water inside the cylinder will only reach a maximum of about 5°-10° lower while its still reheating the contents and assuming the stat promptly turns off the heat source before the water reaches over 60° C.
Tony
