I have a problem with the vent pipe that goes into the expansion tank. Hot water is filling the tank up then overflowing. I have tried to turn the pump to lowest setting but still no joy! any ideas please.
it is constant, any advice please?
Tried that. Also turned all rads on full and bled cylinder, pump and all rads. Any more sugestions please?
Is the cws tank higher than the heating tank?
It can if the cylinder coil is broken.Is the cws tank higher than the heating tank?
Why, will that mean vent expels water?....
As any heatingengineer knows.
When a system is heavily soiled, quite likely when it so bad that the cylinder has rotted away, the 15 mm feed is far from guaranteed to be free of obstructions.
