the cold to both basin and bath is powerful, hot to both is weak
if you say only when called for as in switching the hw on to heat up then the coil has gone in the cylinder passing water from f/e to cws.water in cwsc is clean not dirty
must be an older mixer tap that mizes water in the body,
whats the kitchen got a monobloc mixer or single taps ?james i will fit check valves to both hot&cold to both basin and bath the mixer taps on both are brand spanking new,faulty?
fair enough. good to know. i just thought that all taps fed from a cold water tank now had to have potable water at cold side due to regs!!
